Search results in Plex Web no longer left-aligned
Server Version#: 1.41.3.9314
Plex Web Version#: 4.143.0
When using the search box to find content, the search results list is now centered instead of left-aligned as it was in previous Plex Web versions. Is this a bug or intentional?
Screenshot attached.
I can’t confirm. I’d check my browser add-ins and the server’s DB health.
Thanks Otto. I’m using MS Edge Dev. I cleared the cookies and cache for the Plex app and nothing changed. Ditto for turning off all browser extensions, Ditto for signing out of Plex and back in.
BTW, the problem exists in both the hosted and local Plex Web versions (4.143 and 4.141, respectively. So it’s not due to the most recent Plex Web version update as I originally noted.
Tried Chrome and it works properly. Also tried the release and Beta versions of Edge, and it works properly with them as well. That at least suggests there is no problem with the server.
Tried Edge Canary and it has the same problem as Edge Dev (misaligned search results). That suggests something is wrong with Edge Dev & Canary.
I suppose I should pursue this with MS, but if you are so inclined, I’d be curious if you are able to replicate the problem on your end using Edge Dev or Canary. I don’t know enough to know what MS might have done to cause this behavior, but soon enough it will make its way to the Beta and release versions, and then every Edge user will have the problem.
Fixed in Plex Web 4.145.1
