Server Version#: Jyothi Malla
Player Version#: tvOS 2.15
I have 2 versions of al my 4K content, a 4K HEVC and a plex transcoded version to 1080p, however when I try to playback the 1080p version it fails to play. Other 1080p content plays fine, but the plex versions one all fail.
I have it set to transcode to iOS compatible, which tvOS is based off of and has the same video support.
I tried with both the enhanced player and the tvOS one, neither work failing the same. There is no error, it just fails to play silently. Attached both server and client logs
logging-3.zip (1.1 MB)
Plex Media Server Logs_2020-03-31_23-54-36.zip (4.0 MB)
Would you mind turning DEBUG logging back on? I can’t see what it’s really doing nor are you saving any space (log space is fixed size = 50MB)
I can see you have codec retrieval (network) issues
Mar 31, 2020 06:27:19.238 [0x7f10127fc700] ERROR - LPE: unknown item 35135.
Mar 31, 2020 06:27:19.238 [0x7f10127fc700] ERROR - Sync: failed to generate query for path library://9841bcc3-260b-40a2-8de9-9d37a944f1ba/directory/%2Flibrary%2Fmetadata%2F35135%2Fchildren in sync item 40514620
Mar 31, 2020 06:27:19.238 [0x7f10127fc700] ERROR - Sync: empty sync set, unable to update status for sync list 4879464, sync item 40514620
Mar 31, 2020 06:27:19.535 [0x7f10b15ce700] INFO - CodecManager: obtaining decoder 'mp3'
Mar 31, 2020 06:27:20.018 [0x7f10b1dcf700] WARN - JobManager: Could not find job for handle 372
Mar 31, 2020 06:27:20.018 [0x7f10b1dcf700] WARN - JobManager: Could not find job for handle 607
Mar 31, 2020 06:27:20.305 [0x7f10b15ce700] INFO - CodecManager: obtaining decoder 'aac'
Mar 31, 2020 06:27:20.821 [0x7f10b1dcf700] WARN - JobManager: Could not find job for handle 694
Mar 31, 2020 06:27:21.090 [0x7f10b15ce700] INFO - CodecManager: obtaining decoder 'wmav2'
Mar 31, 2020 06:27:21.645 [0x7f10b1dcf700] WARN - JobManager: Could not find job for handle 739
Mar 31, 2020 06:27:21.881 [0x7f10b15ce700] INFO - CodecManager: obtaining decoder 'hevc'
Mar 31, 2020 06:27:22.479 [0x7f10b1dcf700] WARN - JobManager: Could not find job for handle 771
Mar 31, 2020 06:27:23.460 [0x7f10b15ce700] INFO - CodecManager: obtaining encoder 'aac'
Mar 31, 2020 06:27:24.257 [0x7f10b15ce700] INFO - CodecManager: obtaining encoder 'libmp3lame'
Mar 31, 2020 06:27:25.079 [0x7f10b15ce700] INFO - CodecManager: obtaining decoder 'h264'
Mar 31, 2020 06:27:28.029 [0x7f105bfff700] INFO - Refreshing paths watched by LibraryUpdateManager
Mar 31, 2020 06:27:37.645 [0x7f10777fe700] ERROR - IsDirectory failed boost::filesystem::status: Too many levels of symbolic links: "/Volumes/Media/TV Shows"
Mar 31, 2020 06:27:37.646 [0x7f10777fe700] ERROR - IsDirectory failed boost::filesystem::status: Too many levels of
The last few lines refer to what look like a damaged file system. (it needs checking).
Erg- I had turned it back on and reproduced but it hadn’t. I turned it off because I have Splunk indexing my logs and it sometimes causes me to go over when the media analysis runs.
Here are the new logs:
Plex Media Server Logs_2020-04-05_11-06-40.zip (8.3 MB)
I fixed the sym link issue also, now.
Thanks @ChuckPa !
