Server Version#: 1.20.1.3252
Have been running PMS for many years, has recently started Crashing every night.
Installed on brand new MacMini (copied database from old server) still Crashing nightly.
Only empty folders in Crash reports folder?
Update, I had same issue
Had? did you find a solution?
I found it was the EPG refreshing during Scheduled tasks. So I disabled, also disabled Enhanced guide and changed the update interval. I only used the guide so it really did not matter greatly.
I believe it was a ram issue
I am not using DVR so have no enhanced guide option. I did disable " Perform refresh of program guide data." in Schedule Tasks but still crashing. It looks like it is some scheduled task that is causing the crash, I changed the run time from 2am to 11am and now it crashes in the morning!
Bump: Is there nobody that can help diagnose the reason for this daily crashing?
I’m seeing the same issue. Started happening when I updated to Catalina. Was running an older version of Mac OS prior to this. Not running a DVR - so only looking at my iTunes library.
Mine has not crashed once since I downgraded to Version 1.19.4.2935 more than 2 weeks ago!
I’m running 1.20.1.3252. Unfortunate that we have to play those games - i.e. downgrading to get it to work properly.
