Server dropping in and out of remote access, samsung unable to connect
Showed online previously but did not work on a samsung os. Both the server and app are updated to the latest version. Now the server is going offline as well. I used LAN then switched over to wifi after it wasn’t online with a port forward. That works for around 5min-hours but still no luck streaming on the server account.
Used 32400, port forward with a lan, also a VPN is on. My router has UPnP but it did not work for some reason.
Not sure what to do at this point, unless the VPN is interfering I don’t see how the port forward would be wrong or me being able to change the streaming settings since the Samsung is set up to read 32400 in the plex menu that enables direct IP.
I’d like to create a stable connection now with a VPN rather than later when I might have to switch services or go through the loops again.
Open to options but just saying, the errors have been very minor yet major so far. At least the local server works. Appreciate the help
Server Version#:
