Upgrade my PMS? I’m not sure. I’m just a home user and am not familiar with all these terms. But I upgrade my NAS whenever it wants me to. And I think I recently did. But the problems started after a reboot of the NAS.
I have no antivirus software on the NAS itself, as it is not connected outside my LAN.
The firewall is probably not active for the same reason.
I can play music using my HEAS app from Denon. It accesses a music folder from the NAS. So you are correct it is not via Plex.
Do I understand correctly that the database is nothing else than an inventory with enriched content like pictures and meta data, based on the content of my media folders?
If so, is there a way to let Plex re-inventory those folders? Thus rebuilding its database from scratch? Or is that a next step if this one fails?
I only see files from dec/2021. Is that okay you think? Not too old?
It’s a database, that holds info about your media, the info about them, as well as points to downloaded posters etc. It also holds information about who watched what
If the database is broken, then there’s sadly no way
That sadly indicates, that your database broke then, since if a database is broken, no backup will take place
And as a default, a new backup should take place every 3 days
WAIT! Good news! It works. I guess it needed some time to parse the new database? But it works again… Man! I’m releaved! Thanks for your help @BigWheel@dane22 !
