Server issues?
Hello - I’ve been using Plex for a while now. Been using it without issue on my AppleTV for months. I needed to logout of the app today and after doing so, I can no longer sign back in.
When I click Sign In, it displays a 4-digit code for about 3 seconds, then says “Oops! Refresh Code and try again” (paraphrasing). Only thing I could find is from back in March 2016: https://forums.plex.tv/discussion/210815/oops-something-went-wrong-refresh-code
I uninstalled the app, restarted my AppleTV, then reinstalled. No change.
My server is running ok (Win10). But I cleared past devices in Settings and signed out/in anyway. No change.
Is something just down temporarily? Any idea what’s happening? Really wish I would’ve never signed out. =(
Thanks for any help you can provide!
I should add: It just gets stuck in a loop. I hit Refresh Code, then it flashes a code for a few seconds, then gone again.
Ack! One last thing… Not sure why I said “AppleTV”… I meant Amazon FireTV.
The issue with linking through a pin code should now be fixed
Ok, thanks! I’ll check it out.
Back in business! Thanks again.
