Server Version#: 1.24.0.4921
Ubuntu 18.04
Kernel: 4.15.0-153-generic
Is there a trick to getting Plex to work with Pfsense? That’s the only thing I can think of that’s causing me so many issues. It used to work flawlessly prior to 1.22.X, but things change. All I have set up for it is a port forward, pretty standard TCP/UDP for port 32400 - it’s worked for years. NAT and Upnp all function as expected.
My server’s been losing it’s connection to plex.tv frequently over the last two months and I can’t think of what else I can do on my end.
My router was reset to factory settings yesterday and the issue persists. I’m using Cloudflare for my DNS but I tried Google yesterday and still had a problem.
While my server is “inaccessible” port 32400 is still open according to canyouseeme.org for my IP. It remains inaccessible for upwards for 10 minutes before suddenly becoming accessible again out of the blue, or if I force a restart.
I’ve already started my server from scratch and upgraded the OS to Ubuntu 18.04LTS, so I don’t think it’s the database or metadata. My server itself is still fully functional otherwise, so I have no clue what the issue could be. My LAN is perfectly stable apart from Plex.
I do have multiple interfaces on my server, one being a 4 port bond, then I have a dual 10Gbe NIC and a iDRAC port which both have their own IP’s. In the logs I do see mention of the other subnets from those NIC’s, is it possible that Plex for some reason is switching to using one of the other NIC’s despite my setting the bond as preferred?
Earlier today
Plex Media Server Logs_2021-08-09_17-18-30.zip (6.0 MB)
Maybe several minutes ago
Plex Media Server Logs_2021-08-09_19-43-01.zip (5.2 MB)
Just now
Plex Media Server Logs_2021-08-09_19-57-51.zip (4.6 MB)
Do you guys not see anything on your end?
