Server not found
I have a strange problem, in some occasion I turn on the TV, run plex app on the TV and got the message server offline. Plex is running but I cannot access it locally on the main computer. The way I found to fix it is to kill all the PYTHON process in the task manager.
Same thing happen at one on my friend place. I would try to find a way to avoid this, it looks like a plug in prevent me to access my server. It happens maybe once a week.
Any advice? It’s like that since a year or so.
If you think it’s a plugin, remove all the ones you’ve added. If things look good, add them back 1 at a time. If you want to upload your server logs after the next time you see this, I can check if there is something reported in there.
Good Idea, I will do that, Thanks
