OK. Here we go. The first series of pictures shows what happens when the pattern in .plexignore is *. The documentation says that pattern should match all files in the directory containing the .plexignore file and all sub-directories of that directory.
Here’s the structure of the files and folders, as well as the contents of the .plexignore file. The root of this particular Plex library is /mnt/wd10T/tvshows.
david@myplex:/mnt/wd10T/tvshows/JAG$ ll
total 52
drwxrwxr-x 13 plex plex 4096 Sep 29 13:46 ./
drwxrwsr-x 100 plex plex 4096 Sep 28 22:26 ../
drwxrwsr-x 3 plex plex 4096 Sep 29 16:41 Original/
drwxrwsr-x 2 plex plex 4096 Sep 29 12:35 'Season 1'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 10'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 2'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 3'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 4'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 5'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 6'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 7'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 8'/
drwxrwsr-x 2 plex plex 4096 Sep 29 13:07 'Season 9'/
ddavid@myplex:/mnt/wd10T/tvshows/JAG$ ll Season\ 1
total 7842008
drwxrwsr-x 2 plex plex 4096 Sep 29 12:35 ./
drwxrwxr-x 13 plex plex 4096 Sep 29 13:46 ../
-rw-rw-r-- 1 plex plex 730391209 Sep 29 12:32 'JAG - S01E01-02 - A New Life.mkv'
-rw-rw-r-- 1 plex plex 365127525 Sep 29 12:32 'JAG - S01E03 - Shadow.mkv'
-rw-rw-r-- 1 plex plex 364879092 Sep 29 12:32 'JAG - S01E04 - Desert Son.mkv'
-rw-rw-r-- 1 plex plex 364550121 Sep 29 12:32 'JAG - S01E05 - Deja Vu.mkv'
-rw-rw-r-- 1 plex plex 365000553 Sep 29 12:32 'JAG - S01E06 - Pilot Error.mkv'
-rw-rw-r-- 1 plex plex 364657111 Sep 29 12:32 'JAG - S01E07 - War Cries.mkv'
-rw-rw-r-- 1 plex plex 365351183 Sep 29 12:32 'JAG - S01E08 - Brig Break.mkv'
-rw-rw-r-- 1 plex plex 364781363 Sep 29 12:32 'JAG - S01E09 - Scimitar.mkv'
-rw-rw-r-- 1 plex plex 364852649 Sep 29 12:32 'JAG - S01E10 - Boot.mkv'
-rw-rw-r-- 1 plex plex 364606084 Sep 29 12:32 'JAG - S01E11 - Sightings.mkv'
-rw-rw-r-- 1 plex plex 364889244 Sep 29 12:33 'JAG - S01E12 - The Brotherhood.mkv'
-rw-rw-r-- 1 plex plex 365199555 Sep 29 12:33 'JAG - S01E13 - Defensive Action.mkv'
-rw-rw-r-- 1 plex plex 365050157 Sep 29 12:33 'JAG - S01E14 - Smoked.mkv'
-rw-rw-r-- 1 plex plex 365159671 Sep 29 12:33 'JAG - S01E15 - Hemlock.mkv'
-rw-rw-r-- 1 plex plex 365140230 Sep 29 12:33 'JAG - S01E16 - High Ground.mkv'
-rw-rw-r-- 1 plex plex 365384308 Sep 29 12:33 'JAG - S01E17 - Black Ops.mkv'
-rw-rw-r-- 1 plex plex 365059474 Sep 29 12:33 'JAG - S01E18 - Survivors.mkv'
-rw-rw-r-- 1 plex plex 365131991 Sep 29 12:33 'JAG - S01E19 - Recovery.mkv'
-rw-rw-r-- 1 plex plex 365384678 Sep 29 12:33 'JAG - S01E20 - The Prisoner.mkv'
-rw-rw-r-- 1 plex plex 364877562 Sep 29 12:33 'JAG - S01E21 - Ares.mkv'
-rw-rw-r-- 1 plex plex 364627851 Sep 29 12:33 'JAG - S01E22 - Skeleton Crew.mkv'
david@myplex:/mnt/wd10T/tvshows/JAG$ cd Original
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ ll
total 16
drwxrwsr-x 3 plex plex 4096 Sep 29 16:34 ./
-rw-rw-r-- 11 plex plex 151 Sep 29 15:05 .plexignore
drwxrwsr-x 2 plex plex 4096 Sep 29 16:38 'Season 1'/
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ ll Season\ 1/
total 716344
drwxrwsr-x 2 plex plex 4096 Sep 29 16:38 ./
drwxrwsr-x 3 plex plex 4096 Sep 29 16:34 ../
-rw-rw-r-- 1 plex plex 733521920 Sep 29 16:31 'JAG - S01E01-02 - A New Life.avi'
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ cat .plexignore
# Plex will ignore files that match patterns in this file
# The * is a wildcard character
# For now, ignore all files in this folder and subfolders
And here’s what appears on the Plex screen. Note that two episodes are shown for S01E01. One is the .avi file shown above in /mnt/wd10T/tvshows/JAG/Original/Season\ 1. The other is the episode’s .mkv file in /mnt/wd10T/tvshows/JAG/Season\ 1. By the documentation, I expect the copy in /mnt/wd10T/tvshows/JAG/Original/Season\ 1 to be filtered out by /mnt/wd10T/tvshows/JAG/Original/.plexignore. It is not.
Next, I link the .plexignore file into the Season\ 1 directory:
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ ln .plexignore Season\ 1/
Success! The extra copy of the episode is filtered out. But why did I need to place a .plexignore file in the Season\ 1 directory? The documentation says that the one in Original should filter out files in sub-directory.
Now, I remove .plexignore from the sub-directory to prove that it is not the ignore file in the Original folder that did the filtering.
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ rm Season\ 1/.plexignore
Et voila. The scanner once again finds the second copy of the episode file.
-----------------------End of Test Case Using * as Pattern---------------------
Now let’s try your suggestion that I use ./* as the pattern. I’ll use the same setup as before except this time the single pattern in .plexignore is ./*.
david@myplex:/mnt/wd10T/tvshows/JAG/Original$ vi .plexignore
total 16
drwxrwsr-x 3 plex plex 4096 Sep 29 16:41 ./
-rw-rw-r-- 11 plex plex 153 Sep 29 16:41 .plexignore
drwxrwsr-x 2 plex plex 4096 Sep 29 16:41 'Season 1'/
total 716344
drwxrwsr-x 2 plex plex 4096 Sep 29 16:41 ./
drwxrwsr-x 3 plex plex 4096 Sep 29 16:41 ../
Once again, Plex shows two copies of the S01E01:
Next I link the .plexignore file into the Season\ 1 folder.
This time the scanner doesn’t filter out the .avi file even though the .plexignore file is in the same directory. Why?
I conclude that the pattern ./* does not match any files at all. I further conclude that Plex’s pattern matching algorithm is broken. If I were on site there, I’d write a bug, but it’s a fairly minor bug because there’s an easy workaround: put a .plexignore file in every directory you want files ignored from.
