Server Version#: 1.31.3.6868
Hello,
I was not using the Plex server in the last month, and when I tried yesterday I realized that it didn’t work anymore. In the meantime I had installed NordVPN on my PC, however all the problem persist even when the VPN is completely disabled on my PC.
On the server side, I see it correctly connected. (When I looked in http://127.0.0.1:32400/..)
However, even on the same pc, looking from https://app.plex.tv/desktop the Server seems to be unreachable. (I tried also fto connect from the TV or another device, so I guess the problem is on the server or in my PC web setting.)
I’m not sure if the VPN setup changed something in my configuration that broke my Plex server or is something else, and need some help to understand the cause.
I tried to look in the log, but I don’t understand much… however I found:
Mar 29, 2023 20:05:25.712 [17936] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:1901
Mar 29, 2023 20:05:25.712 [17936] DEBUG - NetworkService: Browsing on interface 192.168.178.30 on broadcast address 239.255.255.250 (index: 0)
Mar 29, 2023 20:05:25.712 [17936] DEBUG - NetworkService: Browsing on interface 10.5.0.2 on broadcast address 239.255.255.250 (index: 1)
Mar 29, 2023 20:05:25.712 [17936] ERROR - Network Service: Error in browser handle read: 995 (Operazione di I/O terminata a causa dell’uscita dal thread oppure della richiesta di un’applicazione) socket=-1
Mar 29, 2023 20:05:25.834 [17936] INFO - Network Service: Abandoning browse socket, it was closed.
Mar 29, 2023 20:05:25.834 [17936] ERROR - Network Service: Error in browser handle read: 995 (Operazione di I/O terminata a causa dell’uscita dal thread oppure della richiesta di un’applicazione) socket=-1
(Sorry for the Italian in the log, I tried to change the language to English in the app, but it seems to stick with the system one…)
Any hints?
Thanks!
