Server on Linux mint showing as offline to apps on same network
Server Version#:1.43.0.10492
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled
Very new to Linux. I was able to play stuff through relay. But once I turned relay off, I am no longer able stream to apps on the same network as the server. I’m in way over my head. I know this has probably been asked a million times but any help would be appreciated. Thank you.
Note 1: don’t use Linux Mint to run your Plex Media Server… it’s known to cause trouble and not officially supported.
Noted. I’ll move over to Ubuntu asap and try it again. Thanks for your help.
Also, configure the network interface on the server to use a public DNS server: 1.1.1.1 (Cloudflare), 8.8.8.8 (Google), 9.9.9.9 (Quad9).
