Server seems offline when not
Server Version#:
Player Version#:2025.27.0 (1288)
Can’t access server. Was working in past. Logs showing missing files. Have reinstalled app on iOS.
2025/10/25 19:20:51.283 (8554789) :minus: (private) | [checkForExistingDownloads]
2025/10/25 19:20:51.297 (8554902) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.333 (8554789) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.350 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.358 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.378 (8554790) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.385 (8554902) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.399 (8554902) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.409 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.430 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.445 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.454 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.517 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.666 (8554901) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.703 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.828 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:51.973 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.396 (8554789) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.408 (8554789) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.431 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.451 (8554294) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.479 (8554901) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:20:56.494 (8554284) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:019 [t9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/pins/390040067 110ms
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:236 [t9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user?includeSubscriptions=1 216ms
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:281 [t9oiugixu3qdbwmbiwoa4pnz] [Download Metadata] Initializing
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:281 [t9oiugixu3qdbwmbiwoa4pnz] [Downloads] Initializing queue
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:283 [t9oiugixu3qdbwmbiwoa4pnz] [User] Skipping token check, last run: 24 seconds ago
2025/10/25 19:21:01.024 (8554284) :minus: (private) | 10/25/2025 19:20:51:285 [t9oiugixu3qdbwmbiwoa4pnz] [Vizbee] Relinking Vizbee HomeSSO SDK
2025/10/25 19:21:01.024 (8554284) :minus: (private) | 10/25/2025 19:20:51:285 [t9oiugixu3qdbwmbiwoa4pnz] [Vizbee] Already initialized, skipping re-initialization
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:321 [daldricht9oiugixu3qdbwmbiwoa4pnz] [MigrateDownload] Starting migration for user: 097b0f97ae03f76b
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:336 [daldricht9oiugixu3qdbwmbiwoa4pnz] [MigrateDownload] Migration completed for user: 097b0f97ae03f76b
2025/10/25 19:21:01.024 (8554284) :minus: (private) | 10/25/2025 19:20:51:336 [daldricht9oiugixu3qdbwmbiwoa4pnz] [NanoDownloads] Checking if downloads need to be migrated
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:338 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/settings/opt_outs 73ms
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:338 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/view_state_sync 70ms
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:341 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/shared_sources/received 65ms
2025/10/25 19:21:01.024 (8554284) :wrench: (private) | 10/25/2025 19:20:51:365 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/privacy 74ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:366 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/097b0f97ae03f76b/settings/bulk?sharedSettings=1&settings[][key]=favoriteLibraries 88ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:367 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/097b0f97ae03f76b/settings/bulk?sharedSettings=1&settings[][key]=adOnboarding 78ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:369 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/profile 56ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:377 [daldricht9oiugixu3qdbwmbiwoa4pnz] [FavoriteLibraries] Updating local favorite libraries to match shared libraries
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:399 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/consent 90ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:418 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 500 https://luma.plex.tv/api/screen/account/ads-consent 132ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:419 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/home/users 103ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:420 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/shared_servers/received/accepted 146ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:431 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/features 116ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:436 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/resources?includeHttps=1&includeRelay=1&includeIPv6=0 165ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:449 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing all 2 connection(s) for Plex_Torres
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:449 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Downloads] Updating background user info
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:457 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing connection for Plex_Torres at https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:462 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/consent 179ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:659 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://luma.plex.tv/api/navigation?flat=1 311ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:814 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 204 https://luma.plex.tv/api/screen/account/ads-consent 464ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:51:965 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 204 https://luma.plex.tv/api/screen/discover/onboarding?accept204=1 612ms
2025/10/25 19:21:01.025 (8554284) :wrench: (private) | 10/25/2025 19:20:56:556 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/user/097b0f97ae03f76b/settings/bulk?sharedSettings=1&settings[][key]=adOnboarding 113ms
2025/10/25 19:21:02.911 (8554789) :minus: (private) | check local network permission with timeout 1
2025/10/25 19:21:03.330 (8554909) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:21:03.346 (8554910) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:01:463 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10006ms
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:01:470 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing connection for Plex_Torres at https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:03:320 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 1849ms
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:03:321 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] No connections available for Plex_Torres
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:03:340 [daldricht9oiugixu3qdbwmbiwoa4pnz] [LiveTVOTASources] Initializing Live TV OTA sources. 0 servers.
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:03:372 [daldricht9oiugixu3qdbwmbiwoa4pnz] [FavoriteLibraries] Library not found for Movies. Server: Plex_Torres. Status: notConnected
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:03:372 [daldricht9oiugixu3qdbwmbiwoa4pnz] [FavoriteLibraries] Library not found for TV Shows. Server: Plex_Torres. Status: notConnected
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:05:507 [daldricht9oiugixu3qdbwmbiwoa4pnz] [LumaScreen] Skipping luma refresh for screen
2025/10/25 19:21:11.469 (8554294) :wrench: (private) | 10/25/2025 19:21:05:507 [daldricht9oiugixu3qdbwmbiwoa4pnz] [PersonalMediaHomeData] Refreshing data
2025/10/25 19:21:26.215 (8554910) :wrench: (private) | 10/25/2025 19:21:16:212 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing all 2 connection(s) for Plex_Torres
2025/10/25 19:21:26.215 (8554910) :wrench: (private) | 10/25/2025 19:21:16:223 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing connection for Plex_Torres at https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400
2025/10/25 19:21:36.234 (8554910) :wrench: (private) | 10/25/2025 19:21:26:231 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10007ms
2025/10/25 19:21:36.234 (8554910) :wrench: (private) | 10/25/2025 19:21:26:242 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Testing connection for Plex_Torres at https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443
2025/10/25 19:21:36.234 (8554910) :wrench: (private) | 10/25/2025 19:21:26:673 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 431ms
2025/10/25 19:21:36.235 (8554910) :wrench: (private) | 10/25/2025 19:21:26:674 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] No connections available for Plex_Torres
2025/10/25 19:21:36.235 (8554910) :wrench: (private) | 10/25/2025 19:21:28:380 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10001ms
2025/10/25 19:21:36.235 (8554910) :wrench: (private) | 10/25/2025 19:21:28:437 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 48ms
2025/10/25 19:22:07.052 (8554236) :minus: (private) | willResignActiveNotification
2025/10/25 19:22:07.060 (8554652) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:22:08.146 (8554236) :minus: (private) | [handleBridgeAppEnterBackground]
2025/10/25 19:22:08.147 (8554236) :minus: (private) | didEnterBackgroundNotification
2025/10/25 19:22:08.157 (8554901) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: true
2025/10/25 19:22:08.157 (8554901) :wrench: (private) | 0 successfully added
2025/10/25 19:22:08.157 (8554901) :wrench: (private) | 0 errored
2025/10/25 19:22:08.180 (8554901) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:22:08.186 (8554901) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:22:08.449 (8554909) :wrench: (private) | 10/25/2025 19:22:08:448 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10004ms
2025/10/25 19:25:58.256 (8554652) :wrench: (private) | 10/25/2025 19:22:08:952 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 502ms
2025/10/25 19:25:58.259 (8554236) :minus: (private) | [handleBridgeAppEnterForeground]
2025/10/25 19:25:58.261 (8554652) :warning: (private) | The file “background_tasks.json” couldn’t be opened because there is no such file.
2025/10/25 19:25:58.283 (8558336) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: false
2025/10/25 19:25:58.283 (8558336) :wrench: (private) | 0 successfully added
2025/10/25 19:25:58.283 (8558336) :wrench: (private) | 0 errored
2025/10/25 19:25:58.534 (8554236) :minus: (private) | didBecomeActiveNotification
2025/10/25 19:25:58.544 (8555841) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:25:58.544 (8554236) :wrench: (private) | Restoring to full player.
2025/10/25 19:25:58.544 (8554236) :wrench: (private) | Stopping Picture in Picture but Picture in Picture is not active.
2025/10/25 19:25:59.816 (8555224) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:26:05.437 (8558335) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:26:05.449 (8558335) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:26:08.263 (8555841) :wrench: (private) | 10/25/2025 19:25:58:534 [daldricht9oiugixu3qdbwmbiwoa4pnz] [User] Skipping token check, last run: 332 seconds ago
2025/10/25 19:26:08.263 (8555841) :wrench: (private) | 10/25/2025 19:25:58:534 [daldricht9oiugixu3qdbwmbiwoa4pnz] AppState changed from background to active. Refreshing data…
2025/10/25 19:26:08.263 (8555841) :wrench: (private) | 10/25/2025 19:25:59:804 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/home/users 148ms
2025/10/25 19:26:08.263 (8555841) :wrench: (private) | 10/25/2025 19:26:08:257 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10002ms
2025/10/25 19:26:18.737 (8558335) :wrench: (private) | 10/25/2025 19:26:08:735 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 468ms
2025/10/25 19:26:18.737 (8558335) :wrench: (private) | 10/25/2025 19:26:15:310 [daldricht9oiugixu3qdbwmbiwoa4pnz] [LumaScreen] Skipping luma refresh for screen
2025/10/25 19:26:18.737 (8558335) :wrench: (private) | 10/25/2025 19:26:15:310 [daldricht9oiugixu3qdbwmbiwoa4pnz] [PersonalMediaHomeData] Refreshing data
2025/10/25 19:26:25.885 (8554236) :minus: (private) | willResignActiveNotification
2025/10/25 19:26:25.896 (8558522) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:26:27.064 (8554236) :minus: (private) | [handleBridgeAppEnterBackground]
2025/10/25 19:26:27.065 (8554236) :minus: (private) | didEnterBackgroundNotification
2025/10/25 19:26:27.076 (8558522) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: true
2025/10/25 19:26:27.076 (8558522) :wrench: (private) | 0 successfully added
2025/10/25 19:26:27.076 (8558522) :wrench: (private) | 0 errored
2025/10/25 19:26:27.092 (8558335) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:26:27.111 (8558675) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:06.409 (8554236) :minus: (private) | [handleBridgeAppEnterForeground]
2025/10/25 19:29:06.411 (8558762) :warning: (private) | The file “background_tasks.json” couldn’t be opened because there is no such file.
2025/10/25 19:29:06.428 (8558524) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: false
2025/10/25 19:29:06.428 (8558524) :wrench: (private) | 0 successfully added
2025/10/25 19:29:06.428 (8558524) :wrench: (private) | 0 errored
2025/10/25 19:29:06.692 (8554236) :minus: (private) | didBecomeActiveNotification
2025/10/25 19:29:06.703 (8558335) :wrench: (private) | 10/25/2025 19:29:06:692 [daldricht9oiugixu3qdbwmbiwoa4pnz] [User] Skipping token check, last run: 520 seconds ago
2025/10/25 19:29:06.704 (8558335) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:06.707 (8554236) :wrench: (private) | Restoring to full player.
2025/10/25 19:29:06.707 (8554236) :wrench: (private) | Stopping Picture in Picture but Picture in Picture is not active.
2025/10/25 19:29:07.969 (8560196) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:14.453 (8560196) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:14.464 (8560196) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:16.697 (8560196) :wrench: (private) | 10/25/2025 19:29:06:692 [daldricht9oiugixu3qdbwmbiwoa4pnz] AppState changed from background to active. Refreshing data…
2025/10/25 19:29:16.697 (8560196) :wrench: (private) | 10/25/2025 19:29:07:954 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/home/users 153ms
2025/10/25 19:29:16.697 (8560196) :wrench: (private) | 10/25/2025 19:29:16:413 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10005ms
2025/10/25 19:29:26.968 (8560354) :wrench: (private) | 10/25/2025 19:29:16:961 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 542ms
2025/10/25 19:29:46.049 (8554236) :minus: (private) | willResignActiveNotification
2025/10/25 19:29:46.059 (8560502) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:47.148 (8554236) :minus: (private) | [handleBridgeAppEnterBackground]
2025/10/25 19:29:47.148 (8554236) :minus: (private) | didEnterBackgroundNotification
2025/10/25 19:29:47.159 (8558762) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: true
2025/10/25 19:29:47.159 (8558762) :wrench: (private) | 0 successfully added
2025/10/25 19:29:47.159 (8558762) :wrench: (private) | 0 errored
2025/10/25 19:29:47.170 (8560501) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:29:47.184 (8560501) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:15.931 (8554236) :minus: (private) | [handleBridgeAppEnterForeground]
2025/10/25 19:30:15.931 (8560500) :warning: (private) | The file “background_tasks.json” couldn’t be opened because there is no such file.
2025/10/25 19:30:15.948 (8560501) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: false
2025/10/25 19:30:15.948 (8560501) :wrench: (private) | 0 successfully added
2025/10/25 19:30:15.948 (8560501) :wrench: (private) | 0 errored
2025/10/25 19:30:16.199 (8554236) :minus: (private) | didBecomeActiveNotification
2025/10/25 19:30:16.207 (8554236) :wrench: (private) | Restoring to full player.
2025/10/25 19:30:16.207 (8554236) :wrench: (private) | Stopping Picture in Picture but Picture in Picture is not active.
2025/10/25 19:30:16.208 (8560998) :wrench: (private) | 10/25/2025 19:30:16:199 [daldricht9oiugixu3qdbwmbiwoa4pnz] [User] Skipping token check, last run: 589 seconds ago
2025/10/25 19:30:16.209 (8560998) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:17.715 (8555841) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:20.082 (8560503) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:20.095 (8560503) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:23.940 (8554236) :minus: (private) | willResignActiveNotification
2025/10/25 19:30:23.947 (8561080) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:24.751 (8554236) :minus: (private) | [handleBridgeAppEnterBackground]
2025/10/25 19:30:24.752 (8554236) :minus: (private) | didEnterBackgroundNotification
2025/10/25 19:30:24.763 (8560641) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: true
2025/10/25 19:30:24.763 (8560641) :wrench: (private) | 0 successfully added
2025/10/25 19:30:24.763 (8560641) :wrench: (private) | 0 errored
2025/10/25 19:30:24.771 (8561080) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:30:24.792 (8561081) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:31:17.320 (8561797) :wrench: (private) | 10/25/2025 19:30:16:199 [daldricht9oiugixu3qdbwmbiwoa4pnz] AppState changed from background to active. Refreshing data…
2025/10/25 19:31:17.320 (8561797) :wrench: (private) | 10/25/2025 19:30:17:698 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/home/users 395ms
2025/10/25 19:31:17.324 (8554236) :minus: (private) | [handleBridgeAppEnterForeground]
2025/10/25 19:31:17.325 (8560998) :warning: (private) | The file “background_tasks.json” couldn’t be opened because there is no such file.
2025/10/25 19:31:17.341 (8561080) :wrench: (private) | Adding 0 download requests - startTasksImmediately: true, useBackgroundSession: false
2025/10/25 19:31:17.341 (8561080) :wrench: (private) | 0 successfully added
2025/10/25 19:31:17.341 (8561080) :wrench: (private) | 0 errored
2025/10/25 19:31:17.586 (8554236) :minus: (private) | didBecomeActiveNotification
2025/10/25 19:31:17.593 (8561081) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:31:17.600 (8554236) :wrench: (private) | Restoring to full player.
2025/10/25 19:31:17.600 (8554236) :wrench: (private) | Stopping Picture in Picture but Picture in Picture is not active.
2025/10/25 19:31:19.183 (8561798) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:31:21.536 (8560502) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:31:21.552 (8560502) :warning: (private) | File does not exist at path: /var/mobile/Containers/Data/Application/92D8F007-8835-41A9-94DA-43E2406B86DB/Library/Application Support/downloads
2025/10/25 19:31:27.330 (8561798) :wrench: (private) | 10/25/2025 19:31:17:586 [daldricht9oiugixu3qdbwmbiwoa4pnz] [User] Skipping token check, last run: 651 seconds ago
2025/10/25 19:31:27.331 (8561798) :wrench: (private) | 10/25/2025 19:31:17:586 [daldricht9oiugixu3qdbwmbiwoa4pnz] AppState changed from background to active. Refreshing data…
2025/10/25 19:31:27.331 (8561798) :wrench: (private) | 10/25/2025 19:31:19:166 [daldricht9oiugixu3qdbwmbiwoa4pnz] [fetchJson] GET 200 https://clients.plex.tv/api/v2/home/users 472ms
2025/10/25 19:31:27.331 (8561798) :wrench: (private) | 10/25/2025 19:31:27:321 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] Fetch timeout GET https://192-168-18-14.12fea82a96854832be7900dbf916ca25.plex.direct:32400/media/providers 10007ms
2025/10/25 19:31:37.577 (8560998) :wrench: (private) | 10/25/2025 19:31:27:573 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Downloads] size: 0 for 0 file(s)
2025/10/25 19:31:37.577 (8560998) :wrench: (private) | 10/25/2025 19:31:27:821 [daldricht9oiugixu3qdbwmbiwoa4pnz] [Connections] GET 401 https://45-79-129-106.12fea82a96854832be7900dbf916ca25.plex.direct:8443/media/providers 488ms
C
