gle96
February 27, 2022, 5:25am
1
Server Version#:1.25.6.5577-c8bd13540
So I have installed Plex Media Server on my Ubuntu 20.04 Server (arm64) and it is currently running. I can access the ‘web’ part by going to ip:32400/web but it will not for some reason allow me to set it up as a ‘server’. After i Login it simply redirects to ip:32400/web/index.html#!/
Any Help would be greatly appreciated.
ChuckPa
February 27, 2022, 6:48am
2
Are you and the server on the same subnet?
Is the subnet in the range as specified by RFC-1918 (Private Network) ?
In Internet networking, a private network is a computer network that uses a private address space of IP addresses. These addresses are commonly used for local area networks (LANs) in residential, office, and enterprise environments. Both the IPv4 and the IPv6 specifications define private IP address ranges.
Private network addresses are not allocated to any specific organization. Anyone may use these addresses without approval from regional or local Internet registries. Private IP address spac...
system
Closed
May 28, 2022, 6:48am
3
