Server Stops Running
After selecting second file on a particular plugin, PMS stops running.
Ok, I have a really weird issue..... I have been working on updating the ABC Fam plugin, and finally finished it. But while testing it i discovered that it works perfectly on the first video file I select, but after exiting the first one and selecting the any other video file from the abc fam plugin, PMS stops running. The log from both the plex.log and plex media server.log are below. Thanks for the help.
Plex.log:
15:32:27 T:2961915904 M:383991808 NOTICE: Display resolution AUTO : 720p 16:9 (Windowed) (1)
15:32:27 T:2961915904 M:383991808 WARNING: Upscale: selected algorithm 0
15:33:10 T:2691344160 M:328085504 NOTICE: Bonjour: Skipping the search because video is playing.
15:33:35 T:2691344160 M:357478400 WARNING: Skin has invalid include: PanelStreamNoThumb
15:33:35 T:2691344160 M:357466112 WARNING: Skin has invalid include: PanelStreamNoThumb
15:33:47 T:2691344160 M:404373504 NOTICE: Bonjour: Did remove service - Rodney Hoyt’s MacBook Pro (2)
15:33:47 T:2691344160 M:404369408 NOTICE: Notifying remote remove host on Rodney-Hoyts-MacBook-Pro-2.local.
15:33:47 T:2691344160 M:404369408 NOTICE: Bonjour: Whacking - Rodney Hoyt’s MacBook Pro (2)
15:34:10 T:2691344160 M:498176000 NOTICE: Bonjour: Skipping the search because video is playing.
15:35:10 T:2691344160 M:497676288 NOTICE: Bonjour: Skipping the search because video is playing.
15:36:10 T:2691344160 M:492945408 NOTICE: Bonjour: Skipping the search because video is playing.
I also found this message furthe rup in the log, could it have anything to do with it, and if so, how do i correct this issue?
8/18/11 5:13:36 PM [0x0-0x221221].com.plexapp.plexmediaserver[5300] 2011-08-18 17:13:36,383 - com.plexapp.plugins.abcfamily (-4faed000) : WARNING (data:178) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting object: line 11 column 13 (char 215)
Another log i found after PMS shut down.
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,500 - com.plexapp.plugins.abcfamily (-4faed000) : INFO (__init__:91) - Season 1 | Episode 1
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,501 - com.plexapp.plugins.abcfamily (-4faed000) : INFO (__init__:97) - Pilot
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,501 - com.plexapp.plugins.abcfamily (-4faed000) : INFO (__init__:98) - http://cdn.video.abc.com/streaming/images/player/episodes/10thingsihateaboutyou/TEN_1001.jpg
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,501 - com.plexapp.plugins.abcfamily (-4faed000) : INFO (__init__:99) - http://abcfamily.go.com/watch/10-things-i-hate-about-you/SH5524459/VD5551604/pilot
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,502 - com.plexapp.plugins.abcfamily (-4faed000) : INFO (__init__:100) - Conflict arises when 2 sisters start a new school with 2 different attitudes.
8/18/11 5:19:23 PM [0x0-0x226226].com.plexapp.plexmediaserver[5321] 2011-08-18 17:19:23,508 - com.plexapp.plugins.abcfamily (-4faed000) : DEBUG (runtime:621) - Response: 200
8/18/11 5:19:49 PM com.apple.launchd[85] ([0x0-0x226226].com.plexapp.plexmediaserver[5321]) Stray process with PGID equal to this dead job: PID 5324 PPID 1 Python
8/18/11 5:19:49 PM com.apple.launchd[85] ([0x0-0x226226].com.plexapp.plexmediaserver[5321]) Stray process with PGID equal to this dead job: PID 5322 PPID 1 Python
8/18/11 5:19:49 PM com.apple.launchd[85] ([0x0-0x226226].com.plexapp.plexmediaserver[5321]) Exited abnormally: Illegal instruction
8/18/11 5:19:49 PM [0x0-0x226226].com.plexapp.plexmediaserver 2011-08-18 17:19:49,826 - com.plexapp.plugins.abcfamily (-5f9558e0) : INFO (pipeinterface:90) - Stopping plug-in
Plex Media Server.log
Aug 18, 2011 15:33:36 [0xb05b0000] DEBUG - LINE: STOP
Aug 18, 2011 15:33:36 [0xb05b0000] DEBUG - Stream closed.
Aug 18, 2011 15:33:36 [0xb052e000] DEBUG - Stream closed.
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - Request: GET /video/:/webkit?url=http%3A%2F%2Fabcfamily.go.com%2Fwatch%2F10-things-i-hate-about-you%2FSH5524459%2FVD5564176%2Faint-no-mountain-high-enough&prefix=/video/abcfamily [127.0.0.1] (1 live)
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - * url => http://abcfamily.go.com/watch/10-things-i-hate-about-you/SH5524459/VD5564176/aint-no-mountain-high-enough
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - * prefix => /video/abcfamily
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - WebKit: [abcfamily.go.com/watch/10-things-i-hate-about-you/SH5524459/VD5564176/aint-no-mountain-high-enough]
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - Found corresponding plug-in: /Users/rodneyhoyt/Library/Application Support/Plex Media Server/Plug-in Support/Data/com.plexapp.plugins.abcfamily
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - Resetting to state playing
Aug 18, 2011 15:33:39 [0xb052e000] DEBUG - Using /Users/rodneyhoyt/Library/Application Support/Plex Media Server/Plug-ins/ABC Family.bundle/Contents/Site Configurations/abcfam.xml with score of 105.
Aug 18, 2011 15:33:39 [0xb05b0000] DEBUG - LINE: HELLO
Aug 18, 2011 15:33:39 [0xa06aa720] DEBUG - Received title ["Ain't No Mountain High Enough" Full Episode - 10 Things I Hate About You - ABC Family].
Aug 18, 2011 15:33:41 [0xa06aa720] DEBUG - Frame was loaded.
Aug 18, 2011 15:33:42 [0xa06aa720] DEBUG - Frame was loaded.
Aug 18, 2011 15:33:42 [0xa06aa720] DEBUG - Received title [Like].
Aug 18, 2011 15:33:42 [0xa06aa720] DEBUG - Received title [Ads by Quigo].
Aug 18, 2011 15:33:42 [0xa06aa720] DEBUG - Received title [Quigo TPP - v0.2].
Ok so after a little more research, I found the attched crash log for Plex. I tried reading it, but it is way over my head. Any help with this would be awesome. Thanks guys.
