Servers lost
got that error now and dont know why. I updated Plex app on m Comp, Plex app on my Server but nothing helps
Do you know what version you had updated to? Looking at your account the server that has not been seen for 7 days (that appears to be at a hosting provider) that should be updated. Important Security Update for Plex Media Server v1.43.2 and earlier
if you did update I would maybe try to restore a database backup as it being corrupt may be the cause of the error.
If you have filesystem access may need to see the server logs.
thanks now it works with the Manuell Update. But now i can´t see my Plexserver anymore and cant find out where to connect.
i found out with ChatGPT, my account was not connected. Think it was a bug or something. But now it works
