Re,
suite a ma reinstallation de plexconnect, j’ai bien acces a plex via monATV mais ce message apparait:
‘aucune section disponible dans la bibliotheque PLEX’
j’ai reinstalle PMS : mais toujours pareil.
voici ce que donne le log de plex connect:
20**:16:13 PlexAPI: GDM: Servers discovered: 1
20:16:13 PlexAPI: Servers (local, plex.tv, MyPlex): 2
20:16:13 PlexAPI: No Response from Plex Media Server
20:16:13 PlexAPI: We failed to reach a server. Reason: Unauthorized
20:16:13 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect-master/PlexAPI.py”, line 432, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 475, in error
return self._call_chain(args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
a votre d ou cela peut il provenir?
Je tourne sur MAcmini avec ATV3
merci davance
