Set up audio synchronization in videos
I think you should add the function to correct audio synchronization in videos, in the PLEX player, many people complain about audio lag and sometimes it is due to transcoding, transmitting the audio to a bluetooth speaker, or simply because they like another audio configuration. All this and more problems would be solved if they copied a little to the “VLC player” that has the “audio delay” function.
“Like” the post if you would also like this feature.
There is a dedicated forum section for feature requests like this.
