Setting the preferred language for updating metadata
Server Version#:latest version
Player Version#: latest version
Maybe not this is the best category of my problems but this was the closest to that.
The problem is that i can’t setting my preferred language as default in the “Fix Match …”.
And i dont think so that the PLEX have no setup for it somewhere, everybody should use english as default.
I use the WEB version in Hungarian, I set the English only for the picture
I would like to update the metadata in my native language (Hungarian) so that the movies and series information will appear in my native language (automatically)
Currently, I can only manually (individually) update metadata to a non-English language
It is possible that the default search / update language may not be English
Thank you for your help
Fix Match should default to whatever you have set for the library itself.
Screen Shot 2020-10-02 at 12.53.53 PM
Thank you for your help :+1: :fist_right: :fist_left:
