I noticed PlexConnect supports several languages. I assume it not uses the same language as the OS or the Plex server. It could be nice if there would be an setting in Plex connect to change this manually for PlexConnect, ignoring the system or Plex server language.
When you change ATV language all Apps, including PlexConnect, will use it.
