Setting to use file name for sorting rather than metadata
I have thousands of TV series. Is there a setting to turn off metadata and/or just use the file name for sorting? Many many files are named properly but getting wrong metatdata and there’s too many to edit individually.
Server Version#: latest
Player Version#: what?
No, that is not possible.
Adding TV Shows to Plex:
  1. Look up your show on TheTVDB
  2. Take the title as it is used on TheTVDB.
    If there is something in parentheses, take that too.
    If the title contains invalid characters (depends on your file system), like § : % *, simply leave them out.
  3. Check the naming and the folder structure of your show.
    Name the top folder of the show exactly after the title on TheTVDB.
    No abbreviations. No additional subfolders. No aliases.
    Add the (year) in parentheses of when episode 1 of season 1 of this show was aired.
  4. Name the episode files according to the above linked naming guide.
    Use the same title as for the top folder. Show's Title (year) - s01e01 - additional info.ext (‘- additional info’ can be left out)
  5. After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
There is software which can automate all the renaming and creating of subfolders etc. Filebot is probably the best of them.
