Settings per folder under TV Shows
I would like under TV shows to be able to have the option on each folder to be able to EDIT. to be able to change the advanced setting for that folder to be able to use the agent I wanted, per folder.
thanks
John
What do you mean per ‘folder’?
Per ‘tv show’ or per ‘season folder’?
If it is per tv show: that is already possible. Perform ‘Fix Match’ and select the desired agent during this procedure.
Well I have some folders that are PBS so no data base will tag them so I do manually. I dont see any option for fix match?
And FYI I meta tag all my movies with METAX, wonderful software and only cost $10 and has wonderful support.
As long as you adhere to the Plex file naming schema, the show will at least appear - although without metadata. Then you go to the top level of the show (i.e. not down into a season nor an episode) and click on the ellipsis ( . . . ).
If your custom show is incorrectly merged with another show, you have to first ‘split’ it out. The split command is in the same place as the Fix Match.
P.S. a few PBS shows (particularly documentaries) are listed on TheTVDB Welcome - TheTVDB.com
