Server Version#: 1.18.2.2029
Player Version#: 3.104.2
Windows 10
in the video aspect section of the pmp settings it states:
Note : The Custom entry means that it uses whatever custom values you may have specified in your mpv.conf file. See: [Advanced Configuration].
does this mean that if you choose not to use the “custom” entry (and instead use “display normally” for example) then none of the entries you’ve made to the the mpv.conf file will work, will be observed by plex, even the entries that have nothing to do with aspect ratio? or does this mean that only aspect ratio related entries to the mpv.conf file will be ignored?
thanks!
