Shared library songs not adding to queue or playlists
So i noticed if i try to add a song from a shared library it says added to queue but when i check the queue its not there. I think the library might be shared via a relay but i can browse and play from the library no problem. Heres a log.
Plexamp.log (1.1 MB)
i think that’s likely the issue, the server with the play queue has to have access to the server with the content.
The logs show success adding the item, I’m guessing on the server side, it’s unable to communicate with the other server so it doesn’t end up getting added.
So i fixed remote access with port forwarding and that did the trick.
Glad to hear!
