Shared Plex recently added view
Server Version#: 1.41.5.9522
I have my homepage setup as:
Continue Watching
Recently added Movies
Recently added TV shows
Recently added Anime
People that I share the access to server have it set to
Continue Watching
But the TV Shows section merge both the Anime and the TV Shows. I’d like to have it force the page layout to be just like mine. Is there a way to do this?
Anime are also TV shows.
Therefore, on the Home page, they get merged into the episode lists from other libraries by the same “TV Show” type.
There is a bug (which will never get fixed, since legacy agents are getting removed, and the web app will be replaced in the long term as well):
If you have a tv show library using a legacy metadata agent
and another TV show library using the modern metadata agent, you may see two Recently Added hubs on the home page.
However, if you leave that app open for a while, both hubs will be eventually get populated with content which has been merged from both TV show libraries.
