Sharing across network segment
Your environment is a typical issue when people buy multiple consumer routers. Thankfully you have decent equipment that allows you to turn both Netgears into just Layer 2 WiFi Access points.
Well I am glad that the my Netgear devices support the feature to make this happen. Will I have to use 1 SSID for both areas?
Thanks.
That is up to you. It does not need to be.
Ok, good. Thanks.
