Hello everyone !
Introduction
I’ve just received my new Shield TV Pro 2019 and feel a bit lost regarding all the framerate and resolution settings available across the Plex app and the OS itself.
Please note that I’ve done a fair bit of research on the subject, but didn’t manage to find answers detailed (yet simple) enough for me (tech guy here, but still relatively newbie in the AV department), hence this topic.
Finally, this topic might look like it could have been split in two (framerate VS upscaling), but it seems to me that these two aspects serve the same recurrent purpose : obtain the best picture quality, while being the most difficult to grasp (compared to “basic bitrate stuff” where “higher is better”).
Regarding framerate
The 2019 Shield model has a “Match frame rate” feature, whereas Plex has its “Refresh Rate Switching” toggle that I’ve been using since its integration on my 2017 Shield.
From what I’ve understood, they both serve the same purpose (i.e. : sync the output refresh rate with the media’s one).
I tend to prefer Plex’s implementation as it’s an automatic switch, whereas with the Shield you have to open the settings menu while your content is playing and fire the “Match frame rate” quick setting every time. Plus the Shield’s implementation is in Beta…
What do you think about the two implementations ? Is there any advantage in using one over the other (aside from the “manual vs automatic” aspect) ?
Regarding resolution and upscaling
The 2019 Shield TV has 3 upscaling modes :
- AI-Enhanced
- Enhanced
- Basic
I swear I can’t find any official information about the differences between the three options. All I could find is this post on AVS Forum (through this reddit), although this seems to be a subjective opinion.
I don’t want to start yet another topic about the AI-Enhanced upscaling, I just would like to understand the differences beetwen the three options, and how they integrate with Plex’s own “Resolution Switching”.
From what I’ve understood, Plex’s implementation aims at switching the output resolution to the media’s one, so that, for example, the TV performs the upscaling instead of the Shield (I’ve just learned through my researches that a fair number of users were asking for this feature because of poor quality issues when the upscaling is done by the Shield. I personally never noticed that with my 2017 Shield, but I also never tried to compare the two approaches).
I came up with the following matrix of possible combinations of settings, assuming playback of 1080p content on a 4K TV, with the Shield set to output a 4K signal by default :
| Shield’s upscaling mode | Plex’s “Resolution Switching” | Device performing the upscale (Shield or TV) |
| AI-Enhanced | ON | |
| Enhanced | ON | |
| Basic | ON | |
| AI-Enhanced | OFF | |
| Enhanced | OFF | |
| Basic | OFF |
Here’s the raw markdown if you want to complete the matrix in your answer :
Raw matrix markdown
| Shield's upscaling mode | Plex's "Resolution Switching" | Device performing the upscale (Shield or TV) |
| Enhanced | ON | |
| Basic | ON | |
| Enhanced | OFF | |
| Basic | OFF | |
Here are my questions for this part :
- Could you fill the matrix above (or provide another one if I’m missing something) ?
- What are the differences between the Shield’s 3 upscaling modes (mostly between “Enhanced” and “Basic”, as we all know what the AI mode is by now) ?
- What is the best combination of settings (subjectively and/or objectively, if that’s even possible), regarding resolution, to obtain the best picture quality ?
- (this question is related to the previous one) What do you think about the Shield’s upscaling in general ? Have you indeed experienced poor quality compared to your TV’s upscaling ? For those who were able to compare both the 2017 and 2019 Shield models, is there really a difference in that department between the two (aside from the AI upscaling), as suggested in some places, like in the AVS post above ?
Any additional information/explanation or link to great external resources are highly welcome =)
Thanks !
Scentle5S
