Short playback lags
I am using Raspberry Version B with Rasplex 0.4. RC3. I am getting short stops and legs when playing back 1080p movies from my pled server. I used 3 different wifi access point with 2,4 and 5 ghz. I never had any problem when playing these movies with pled on my macbook over wifi.
Before I buy a long ethernet cable I want to be sure that it is the slow wifi connection. I copied the log but I don't understand the errors.
Settings I use:
  • direct play
  • buffer 15%
  • a/v sync on
  • always sync frame rate at start
I appreciate any help!
21:47:29 T:3045994496  NOTICE: GL: NPOT texture support detected
21:47:29 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:47:30 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:47:52 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:47:54 T:2899309664   ERROR: Previous line repeats 1 times.
21:47:54 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:47:55 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:48:17 T:2899309664   ERROR: Previous line repeats 4 times.
21:48:17 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:48:17 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:48:18 T:2743071840 WARNING: CPlexHTTPRemoteHandler::updateCommandID no commandID sent to this request!
21:48:19 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:48:30 T:2899309664   ERROR: Previous line repeats 2 times.
21:48:30 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:48:35 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:48:37 T:2899309664   ERROR: Previous line repeats 1 times.
21:48:37 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:48:42 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:48:53 T:2899309664   ERROR: Previous line repeats 4 times.
21:48:53 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:48:54 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:14 T:2899309664   ERROR: Previous line repeats 6 times.
21:49:14 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:15 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:19 T:2899309664   ERROR: Previous line repeats 1 times.
21:49:19 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:22 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:23 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:24 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:27 T:2899309664   ERROR: Previous line repeats 1 times.
21:49:27 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:28 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
21:49:29 T:2505045088 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer
21:49:31 T:2589426784 WARNING: Previous line repeats 11 times.
21:49:31 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:32 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:33 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
21:49:36 T:2899309664   ERROR: Previous line repeats 1 times.
21:49:36 T:2899309664 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
21:49:40 T:2589426784   ERROR: Error: Requested setting (pvrplayback.scantime) was not found.  It must be case-sensitive
I have no answer to your problem but I am in a quite similar situation : my plex server is one one of my macbook.
When I stream content from my server to my other macbook (both connected over wifi), I have never encountered any lags or stops.
When i stream content to my rasp (server connected over wifi and rasp over ethernet, cache set to 30%), I get those annoying lags..
Maybe this is a bug to report on github?
I like to add, That rasp is cabled to my airport express. And airport express is just 5m away from my airport extreme. Signal and Noise is Perfect!
Wait for RC4 or the stable release, it should fix a lot of these issues.
