Show Exists on TheMovieDB and TheTVDB but Plex keeps forwarding it to different match
Plex Keeps trying to match Untold: Swamp Kings (2023) with Untold (2021). Even entering in the tvdb and tmdb id’s when trying to match, it still only returns Untold (2021).
It looks like things are mixed up because Untold: Swamp Kings is a miniseries but also included as episodes season 3 of the show Untold.
The TVDB has it as a Show: https://thetvdb.com/series/untold-swamp-kings
And also as part of the Untold Series: https://thetvdb.com/series/407414-untold/seasons/official/3 Which is how Plex is listing it
https://watch.plex.tv/show/untold-2/season/3/episode/4
Also, the TMDB seems to list those individual episodes as their own specific show
themoviedb.org/tv/231297-untold-swamp-kings?language=en-US
A search for “Untold: Swamp Kings” which is the title that matches both TVDB and MovieDB.
Searching for it by “tvdb-437826”
The show exists on TVDB and MovieDB but it doesn’t get matched no matter whether I search for the ID or the show Title, it keeps forwarding to the Untold (2021) series.
I would try the name without the Colon .
Untold Swamp Kings (2023)
No Luck
I even tried to search Untold Swamp Kings (2023) with the year left blank, and with the year as 2023, and same results.
I should note that I tried searching for “Swamp Kings” and left out the Untold and didn’t find anything
Have you tried naming the show folder as Untold Swamp Kings (2023) {tmdb-231297}
How are the episodes named?
No luck
Untold - Swamp Kings (2023)
Season 1
Untold - Swamp Kings - S01E01.mkv
Untold - Swamp Kings - S01E02.mkv
Untold - Swamp Kings - S01E03.mkv
Untold - Swamp Kings - S01E04.mkv
The show also doesn’t exist in Plex’s Discover. Which is odd if plex uses TheTVDB or TheMovieDB to pull the populate their agent. They might not though. I’m not sure where they pull data from to populate their agent.
Ah looking at IMDb I see what Plex are doing, you’re right. They’re pulling from IMDb for episodes information and TVDB listing your quoted above. Wikipedia also has the show listed as a collection of Netflix docuseries under the untold banner. Plex are doing the same I guess.
The issue seems to be that all of these below got merged into one show.
…IMDB afaict only has the show as a whole.
…TMDB has two seasons as separate shows but not the show as whole
…TVDB has the full show and two of the seasons as separate shows
<Guid id="imdb://tt15402976"/>
<Guid id="tmdb://208264"/>
<Guid id="tmdb://231297"/>
<Guid id="tvdb://407414"/>
<Guid id="tvdb://433006"/>
<Guid id="tvdb://437826"/>
I’ve made report for our metadata team
@BigWheel Awesome, thank you for reporting that.
