Plex won't match show
I have a TV show: “Paranormal Caught On Camera (2001)”. Plex doesn’t match it even though FileBot finds it fine and it exists on the TVDB site:
https://thetvdb.com/series/paranormal-caught-on-camera
I even tried matching by the TVDB ID: 359573. No luck.
The one episode I have is in a folder of the named “Paranormal Caught On Camera (2001)” and I have tried it in that root folder as well as creating a season subfolder. Doesn’t matter.
Am I missing something else?
Thanks!
Paranormal Caught On Camera Isnt a 2001 show, its a 2019 show. Try doing the plex dance, and then putting the files in a folder called Paranormal Caught on Camera {tvdb-359573} what are the episodes named as?
Well…Plex finds it using your method or by changing the name of the folder to have “2019” in it instead of “2001”., but if you look at the TVDB website it says 2001. Also, if you use FileBot it identifies it as 2001 and named the individual episode properly with 2001 in the name.
How is it that the Plex agent is right, but the data source that it’s supposedly pulling from is wrong? Isn’t Plex still using TVDB as the metadata source?
TVDB lists 2001 on the main page -
But the seasons page shows 2019 -
https://thetvdb.com/series/paranormal-caught-on-camera/allseasons/official
So there seems to be some inconsistency and perhaps it depends where the apps are pulling data from. Not the first time that TVDB has had mistakes or inconstancies.
I would suggest using IMDB to identify your episodes first and then label them according to that in your file folder. then do a file match in Plex.
Thats because someone has been screwing with it recently. It was listed as 2019
EDIT: Someone typoed the S04E11 date from 2021 to 2001
I wouldn’t suggest using IMDb as a reference; it isn’t a primary source for Plex’s consolidated database.
Ideally, I would suggest using FileBot (or Sonarr), and embedding TVDB IDs into the show folder names. Show Name (YYYY) {tvdb-XXXXXX}
Behind that, I would suggest using TVDB as the primary source for show naming and ordering info.
It looks like this show has now been corrected at the TVDB.
I suggest IMDB as a reference source to verify the show information is correct, because some downloads will have different season and episode data embedded in their coding and sometimes the only way to correct this is to completely rename it in plex with a verified source such as IMDB. The metadata scans from the source file so if the embedded code not the title is incorrect then the search results will be incorrect as well.
