Show library in search results?
I have different libraries for different languages and formats and when I search for something I get shown a lot of duplicates from the different libraries, but there is no info which library an item is in.
Having a simple label indicating the library which the items are part of would improve the search a lot. Do you think this is possible?
Which Plex apps are you using and what version of PMS do you have installed?
It definitely shows which Library on the Browser Client
It works fine on the latest versions of the Android app (but not Android TV). In Plex Web it works in the search preview if I do not submit the search query, but if I submit the search query and it displays the search results page, the library isn’t shown anymore. The results are only categorized by Movies or Shows. PMS version is 1.18.4.2171
Edit: I noticed it does show the libraries for some items, but not for all of them. I believe it shows the library only if the item exists in multiple libraries.
