Not sure if this is the correct forum for this. I assumed there would be a DVR/Live TV section…
I was just setting up a series recording for the new Hawaii Five-0 show. The only thing that comes up when searching the Program Guide is the old 1963 show. Even though I know a new episode of the new show comes on Friday.
Upon further investigation, I realized that the new episode is listed under the old show, mixed in with it’s re-run episodes.
I am able to add the recording simply by filtering it to new episodes only, but the show artwork, etc. is wrong.
How do I fix something like that?
The only thing you can do is report it, again. This seems to be a common problem with the guide providers. MacGyver is another one that has this problem.
https://forums.plex.tv/discussion/281569/reporting-gracenote-epg-data-issues#latest
Unfortunately, the instructions here no longer work to determine the EPG source. There is no ellipses to click on for me.
https://support.plex.tv/hc/en-us/articles/115001324354-How-to-tell-if-DVR-EPG-is-OnConnect-or-EyeQ
You can also do a fix match from the show in your library. You may also need to fix the year in the filenames of Shows.
Yeah, I knew I could fix it after it’s recorded. The issue was being able to initially find it and then differentiate it from the old show in the Guide.
I had previously recorded the show via Windows Media Center. So, I already have previous episodes correctly matched in the library. I’m assuming that, even though I am recording the show under the 1963 show’s “umbrella”, it will still match correctly after being added to my library. We shall see!
(I need to look into the MCEBuddy/Comskip setup you have going. I used MCEBuddy to convert the WMC recordings to mp4, but Comskip always seemed to chop off bits of the show, so I stopped using it. – Any guides you can point me to?)
