These two shows now have duplicate tvdb ids associated with them in plex due to them changing at tvdb. Plex rarely (if ever) picks these up so it will need to be fixed manually. Details below …
At least on TVDB’s side it looks like it was unintentional though bumbled (and weirdly resolved - what good is a backup if it just creates a new reference instead of restoring back to original state?).
For my own education, how did you figure that out ? I’m very much a tmdb person and only look at tvdb as a last resort but am curious as to how you figured that out.
They aren’t very transparent usually but if you create a login you can access the Notes section and that can usually get you some indicators. It’s rarely “official” but sometimes you’ll get info from folks who have access to the more official chats\power user areas.
Hmm, that’s odd. Or I misunderstood your post. I’m fairly certain that 350665 is the original TVDB ID for The Rookie since 2018. I have this show set up in FlexGet, and this is the ID I’ve been using since the show premiere.
Or did they deleted it and restored the wrong one, and then restored this one back?
Your right, it was. I cannot speak to the processes at tvdb but something within the last week or two resulted in it changing from 350665 → 465258 causing plex to now have two ids. You can see this very easily if you try and match using tvdb-350665 and tvdb-465258 as both match the show.
Whatever metadata code plex use to detect id changes appears to never or very rarely do cleanup when this type of thing happens (Dope Girls has been a problem since January). If your interested this script Audit duplicate Plex guids · GitHub from @SwiftPanda16 and this thread can provide more information.
