Simple Folder view as on Computer
Server Version#: 1.19.2.2737
Player Version#: No clue
Is there a way to just browse folders with files, no library stuff, just plain old browsing files?
You can switch individual libraries to folder view.
However… that’ll provide you with a very minimalistic functionality.
You should be able to change what is being displayed (same as you would switch between artists/albums/tracks for music or shows/seasons/episodes for tv shows).
https://support.plex.tv/articles/navigating-the-big-screen-apps/
I´ve done the sidebar thing and I’m in folder view, but… its a poor mans files list.
Many of these mediacontent/server/stream apps use some kind of library (which looks nice) but all I want is just a simple “files sorted på filename in folders” list and I bet I’m not alone. It should really be an option.
