When there is no match or an incorrect match, there is the option to fix it. But the moment you click the “Fix incorrect match”, Plex tries (again) to find a match automatically and it disregards the manual input if it’s not done searching.
It seems like a tiny problem because it is five to ten seconds, but when you are trying to fix hundreds of non-Western films, this delay is really frustrating.
The fact is that if you click the “fix” option, it is because Plex could not find it in the first place. I would like to be able to simply manually make the correction (usually providing an imdb id) without having to wait for each one of these films.
All it takes is for Plex to stop its automated search when you click the “Search Options”.
