Single layer dolby vision MKV not being detected in metadata on nvidia shield plex server
I am using the Nvidia Shield TV Pro (2019) device for this, and all files are local storage on that device via USB. I am accessing the library from the web app on the same local network, to organize things.
Setup: Nvidia Shield TV Pro HDMI → LG C9 Oled and then the C9 HDMI eARC → LG SN11RG 7.1.4 atmos system.
Server Version#:1.18.0.1913
Player Version#: 7.23.0.13018
Hi, I have some dolby vision UHD 4k discs ripped with MakeMKV version 1.15.4 and the metadata for the dolby vision is not showing up in plex like in other posts that I’ve seen. I only see this:
Codec HEVC
Bitrate 53346 kbps
Language English
Bit Depth 10
Chroma Subsampling 4:2:0
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K (HEVC Main 10 HDR)
Codec TRUEHD
Channels 8
Language English
Audio Channel Layout 7.1
Bit Depth 24
Sampling Rate 48000 Hz
Title Surround 7.1
Display Title English (TRUEHD 7.1)
The Dolby atmos plays fine in this title, Matrix (the first one) 4K.
Is there something I’m doing wrong or is my version not supporting dolby vision, and only the test versions of plex?
Here’s the media info from “mediainfo” for that file.
Video
ID in the original source m : 4113 (0x1011)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 16 min
Bit rate : 48.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.246
Stream size : 46.6 GiB (89%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : BT.2020
Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 992 cd/m2
Maximum Frame-Average Light : 518 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source m : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 420 kb/s
Maximum bit rate : 7 794 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 4.21 GiB (8%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Try a newer version of PMS. That’s a year old. :slight_smile:
I updated the app and the server and that fixed it! Thanks!
I’m new to this.
