Size of transcoded subtitle
Is it possible to increase the size of the transcoded subtitle, currentlt It's to small to read normally. With the subtitle directplay option I'm be able to change it, but at a resume it starts the srt from the beginning while the movie is at 30 minutes.
The setting for plex web isn't working because This is one is saved in a cookie, so just for the webbrowser itself.
How do you guys interact with This issue? Or should I change some setting??
Thanks!
Thanks!
Have you tried changing subtitle size in Preferences?
Regards
Yes, I did and is working fine. But the downside on that option is that it gets out of sync when you start a movie at a later time as 00:00, like to resume it. The subtitle srt will start from the beginning and the movie is at another playtime.
To corrected that issue, I enable the option to always transcode the subtitles within Rasplex. The settings for the subtitle size is ignored when the transcoding for subtitles is enablad.
Did you search the whole Plex forums before posting, this appears to be an issue with a number of Plex clients, so I suspect that PMS is the problem and how it handles resume when direct playing with subtitles, only seems to affect .srt subs, but then I only spent a couple of minutes searching. Doesn't appear to be a Rasplex specific issue.
Regards.
Yes, I did a search but just find some threads which also be specific for like the Roku or Chromacast.
.... only seems to affect .srt subs ....
So do you mean that if I convert the .srt file to SMI or SSA the subtitles will get back in sync?
