Skateboarding Video Metadata Agent
Hello reptoid1. I haven’t used or tested the Metadata-Agent for a long time now. However the plan is still to finish it someday (including covers). As I mentioned before skatevideosite.com does not have an API. Therefore I had to kind of screen-scrape the skatevideo information from the site. Well knowing that this approach might result in exactly the kind of problem you are describing in case they change the basic layout of the website. I haven’t checked that yet but I will have a look into this today. Is the problem only appearing with a particular skatevideo or all of your videos?
Sent from my iPhone using Tapatalk
Hey Daniel, thank you for the reply and the work you have put into creating and sharing this awesome agent.
I assumed the issue was most likely due to a change on the skatevideosite side or potentially a plex update. The agent was working flawlessly for me in the past.  Unfortunately, I get similar html data for any additional videos I add to the collection.
Ok. I will have a look into it and keep you posted
sorry to open an old thread. Has there been any update on this?
If Skatevideosite don’t allow you to scrape from it and have watermarked images, how about we try to get our own database made? I could probably put together a front end ( in time) for people to submit the videos to and we can build up a database of videos and can scrape from that? Maybe a bit ambitious but would be worth it long run
…please continue the project!!! Didn’t work correctly anymore! :frowning:
