Skip Ads in Recorded Shows
Posted this before. I found that I can reduce the length of time the start and end of a commercial is shown by changing the comskip.ini settings from 0 to 4. You’ll see the 5 sec countdown to 1 right before the commercial starts.
See: Customizing How Commercials are Located and Removed
Change the Plex comskip.ini Settings from 0 to 4
remove_before=4  ; Set the amount of seconds to remove before ALL commercials
remove_after=4   ; Set to the amount of seconds to remove after ALL commercials
