Skip Intro DB location
Where in the DB are the time stamps stored for the Skip Intros?
They are actually stored in the XML file
What are you trying to do with it?
If you just want to see what media has Intro markers … ExportTools or WebTools-NG can dump it.
It’s encoded as the intros element in media_parts.extra_data.
It’s stored URLencoded in the DB, here it’s decoded for visibility. I’d love to hear if this is a standard format, but I think it’s unique-to-Plex internal thing.
ma:container=mkv&ma:deepAnalysisVersion=6&ma:requiredBandwidths=2545,2545,2545,2545,2545,2545,2545,2545&ma:videoProfile=main 10&mi:indexes=sd&pv:chapters={"Chapters":{"Chapter":[{"name":"","start":0.0,"end":39.406033333},{"name":"","start":39.406033333,"end":404.237166666},{"name":"","start":404.237166666,"end":888.888},{"name":"","start":888.888,"end":1314.479833333},{"name":"","start":1314.479833333,"end":1352.864}]}}&pv:deepAnalysisDate=1610267166&pv:intros={"MediaPartMarkersArray":{"attributeName":"intros","version":5,"MediaPartMarker":[{"startTimeOffset":8170,"endTimeOffset":35497}]}}
I’m not aware of an API to programmatically interact with this.
@CostaHT there’s no stored XML file. The View XML button extracts data from all over the database and formats it for presentation or API use.
The XML doesn’t exist. It is generated in real time from the various places where Plex is storing metadata.
That doesnt seem to be the case. I found a show/episode that I know has a working “skip intros” the etra_data doesnt show it. The 4 chapters do align though.
ma:audioProfile=dts&ma:container=mkv&ma:videoProfile=advanced&pv:chapters={"Chapters":{"Chapter":[{"name":"","start":"0","end":"112.57700000000001"},{"name":"","start":"112.57700000000001","end":"709.86300000000006"},{"name":"","start":"709.86300000000006","end":"1280.73"},{"name":"","start":"1280.73","end":"1384.4340000000002"}]}}```
What is the problem you are trying to solve?
Maybe I want to write my own/edit values here using SQLLiteDB. Maybe I want to run a report to see what shows are missing them. There are lots of valid use cases. Can I put them in a NFO file or the new .plex file?
I don’t think there are multiple mechanisms. On that episode, is there a marker with type="intro" in the XML?
no
You can use them, you can’t create and/or modify them.
And that’s obvious since it’s a Plex Pass feature
