Skip intro no longer an option after migrating from PC to NAS
I recently transferred my entire library over to a qnap NAS TS-464. While my library was set up on my PC I could skip intros. The pop up does not appear even though it is enabled in the settings after the move. I have the Lifetime plex pass and I am signed into the same account as before. Thanks in advance!!!
Server Version#: 5.0.1.2277
Player Version#: Android TV
If the paths to your files changed, maybe Plex is still re-scanning the intros.
You can force Analyse a Library or a show at a time to see if that will fix your issue.
The NAS has been up for almost a month now and even new stuff doesnt have the skip intro option. I have forced a rescan and “scan my library periodically” is checked for hourly.
Just to clarify, a regular library scan does not trigger intro detection
SE56 is referring to the choice in the menu specifically called “analyze”
Entire library scan
Screenshot (619)
Per Show
Screenshot (620)
Also look here to see what your settings are
Library → Generate intro video markers
Yes I tested that on an episode and then on an entire season and still no intro skip.
