Skybox VR not finding DLNA server
Server Version#: 1.40.3.8555
Player Version#: Skybox version 1.1.8
I haven’t been able to access my Plex DLNA server from Skybox VR on the Quest 3. I contacted Skybox’s support and according to their logs Skybox’s DLNA module is working perfectly.
Plex DLNA Logs:
Jun 24, 2024 17:22:28.094 [0x70000e1c5000] INFO - Plex DLNA Server v1.40.3.8555-fef15d30c - Apple MacBookPro16,1 x86_64 - build: darwin-x86_64 - GMT -04:00
Jun 24, 2024 17:22:28.096 [0x70000e1c5000] INFO - MacOSX version: 14.5.0, language: en-US
Jun 24, 2024 17:22:28.096 [0x70000e1c5000] INFO - Processor: 16-core Intel(R) Core™ i9-9880H CPU @ 2.30GHz
Jun 24, 2024 17:22:28.096 [0x7ff84ad72fc0] DEBUG - Unique device name = 7e096d47-4c97-8c1d-fb88-cbe3df0116b8
Jun 24, 2024 17:22:28.096 [0x7ff84ad72fc0] DEBUG - DLNA server port: 32469
Jun 24, 2024 17:22:28.096 [0x7ff84ad72fc0] DEBUG - PMS: http://127.0.0.1:32400/
Jun 24, 2024 17:22:28.096 [0x7ff84ad72fc0] DEBUG - MyPlex: https://plex.tv/
Jun 24, 2024 17:22:28.102 [0x7ff84ad72fc0] DEBUG - Reading system DLNA client profiles
Jun 24, 2024 17:22:28.127 [0x7ff84ad72fc0] DEBUG - Read 22 DLNA client profiles
Jun 24, 2024 17:22:28.130 [0x7ff84ad72fc0] DEBUG - DLNA device discovery enabled every 60 seconds
Jun 24, 2024 17:22:28.130 [0x7ff84ad72fc0] DEBUG - Initialization complete
I have Upnp enabled in my router. Is there anything else I can try?
Are the Plex server and your Quest 3 in the same network/subnet?
DLNA cannot stream across networks.
Thanks for your response! Yes, however I do have a Wifi extender from Verizon. When I look at the network on the Quest 3 it gives the router’s IP as the gateway, so I think it’s connecting to the router not the extender, which the plex server is connected to as well.
Figured it out - the laptop I am using is a Macbook which had the firewall enabled which was blocking all incoming traffic. Disabling the local firewall as described in https://support.plex.tv/articles/201543147-what-network-ports-do-i-need-to-allow-through-my-firewall/ allows Skybox to reach the Plex DLNA server.
All set - thanks for your help!
