Server Version#: 3.102.0
Player Version#: 3.102.0
Hi everyone, new user first post here. I’m having problems getting a quality stream from my server when outside the network. The stream rarely gets above .7Mbps. When set to automatic it will switch from .3 to .7. I can manually set it to something higher, but anything above .7 just takes forever to buffer. Netflix and Hulu stream fine on both. Both the server location, and the streaming location test at 14Mbps down, 3Mbps up. Nothing else on either system using bandwidth. Optimized a video to test it and got the same results. If you would like to see logs just let me know witch ones I should post. Thanks
