Yeah, unfortunately ‘TV Movies’ have the same issue as ‘Videos’.
Fixed the other few you mentioned!
I’ve got another one…
First Kill - tt5884234
Fixed
This one isn’t working today… it took it 15 minutes just to pull any data at all! I thought it may just be my connection but others are working fine.
Avengers: Age of Ultron - tt2395427
@chriskeens - That one appears to be working on my end, so I think you are having a different issue. Maybe you could open
a new thread and attach logs of a refresh?
sorry to jump ship but how have you managed to get the imdbs score to show please? :o
I thought it might be something else, anyway after a bit of perseverance it has now pulled the rating fine ![]()
You have to use the plex movie agent to scan your database, making sure that you have selected IMDB as the rating source in settings
@chriskeens said:
a new thread and attach logs of a refresh?I thought it might be something else, anyway after a bit of perseverance it has now pulled the rating fine
sorry to jump ship but how have you managed to get the imdbs score to show please? :oYou have to use the plex movie agent to scan your database, making sure that you have selected IMDB as the rating source in settings
Thankyou, would you be able to point me to where in the settings this option please. I cant seem to find it no where
On your server you go into the settings, select ‘server’, then select ‘agents’ from the left hand side. Next you select ‘Plex Movie’ to show that agent which will bring up a list of the available additional agents. Now click the cog icon to the right of the plex movie agent to bring up the ‘Plex Movie Settings’. Under ‘Ratings source’ select IMDB.
All you need to do then is make sure that your library is using the Plex Movie Agent to scan (from the server home page, hover over your movie library and click the 3 dots, then click edit, select advanced and make sure the agent drop down is set to ‘Plex Movie’.
Now just refresh the metadata for the library and the IMDB ratings should be shown (some of the movies may need a couple of refreshes/rematches to get it to work)
You will find that option when you edit a library.
Seem to have the same problem with Adult Life Skills (tt4211044)
I have another one…
Amelia 2.0 - tt3831344
I fixed Adult Life Skills, but something else is going one with Amelia 2.0 that I am still looking into, sorry!
And another: Air (tt2091478)
@Lightkeeper - that one should be working already. Please clear your http cache and if the problem continues, post logs. Thanks!
Clearing http cache helped. Thanks ![]()
Hmm… maybe Airplane vs Volcano (tt3417334) + Airport (tt0065377) then?
Both of those should be working, too, @Lightkeeper
Hi, I’ve been struggling with previously mentioned title: Beasts of the Southern Wild - tt2125435
All other titles work fine.
Thanks in advance
Still working on the IMDb fix for Beasts of the Southern Wild and Amelia 2.0 - sorry!
