Server Version#: 1.16.6.1592
Player Version#: Irrelevant
I am not sure what’s causing this, or why it only happens SOMETIMES. But once it does, it can’t be fixed.
As you can see, when sorted by Critic Rating, some (most) movies correctly grab the IMDB rating. Some movies on the other hand, don’t, and give me some STAR (*) based % rating out of 100, rather than the IMDB rating out of 10.
Yet on the other hand alltogether, some movies, like the one you see, show literally no rating, no imdb rating, nothing, BUT, they grab the other meta data (description, poster, etc), It’s not like IMDB doesn’t have a rating for this in this case… It does, checked it as I typed it, and IMDB has 15000 votes for this particular item, and yet Plex didn’t scrape it.
What’s most frustrating is, even if I UNMATCH IT, and MANUALLY REMATCH, it wont find it.
What’s even more troublesome, as I mentioned above, there doesn’t seem to be a way to UPDATE IT PROPERLY.
For example look at this grossly erroneous information that got scraped, AND THEN SUBSEQUENTLY WON’t UPDATE!
This movie shows up as 82%, when in reality it is 6.6, again, tried to “Refresh” - no update, tried to unmatch, and rematch, nope, still stays at 8.2
What gives???
And why is it only SOME of the movies???
How do I get it to update?
