Noticing that when you mark a song in your Plex library with (Five Stars) then if you create a Smart Playlist that collects those five Star rated songs, if that same song is in your library in other albums, they also show up. Since a person may have several versions of the same song with lesser fidelity or sound quality, this is frustrating. I’d only want that one version of the song that I marked as five starts to show up. Can this be fixed or is this intentional?
Yeah, it’s a problem that has been reported before. No fix available so far.
That can’t be! And I thought that I had done something wrong.
Have you already provided a solution to this?
No solution provided and the behavior still exists with the latest version, unfortunately.
