Smarthub integration not working
Server Version#: 1.20.4.3517
Player Version#: 5.3.1
So this is sort of a continuation from another thread where I was discussing with someone that I got a new Samsung 50Q60T but when in Smarthub I don’t see the bar that shows the deck and recently added items. He pointed out that there’s a setting for it but I couldn’t find it.
I eventually found it and it was on but it wasn’t working. I turned it off, watched a episode of something then turned it on and watched another episode but the integration still isn’t working.
In addition to this the reason I wasn’t finding the option to begin with is because the menu system isn’t all that user friendly, it’s menu on the left and sub menu on the right but the box for sub menu is same size as menu even though the bottom of that box is for descriptions. IF you don’t know that though and you just scroll the menu then you don’t realize that you aren’t seeing ALL the sub menu items (like I did) hence you miss stuff. like I did.
My SmartHub integration started working with the update to 5.4.1 so thanks for that.
