thank you for the logs.
- The transcoder is engaging with hardware transcode and hw tone mapping.
Apr 13, 2023 00:05:36.552 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] Starting a transcode session l5pr5m4tm1cleumajmheoc9m at offset -1.0 (state=3)
Apr 13, 2023 00:05:36.552 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] TPU: hardware transcoding: using hardware decode accelerator vaapi
Apr 13, 2023 00:05:36.552 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] TPU: hardware transcoding: zero-copy support present
Apr 13, 2023 00:05:36.552 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] TPU: hardware transcoding: not using zero-copy because subtitle burning is required
Apr 13, 2023 00:05:36.553 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [Universal] Using local file path instead of URL: /USB-Drive/Movies/WALL·E (2008) {imdb-tt0910970}/WALL·E (2008) {imdb-tt0910970} [Bluray-2160p][HDR10][TrueHD Atmos 7.1][x265]-Prof.mkv
Apr 13, 2023 00:05:36.553 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] Codecs: hardware transcoding: testing API vaapi
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x41524742 → bgra.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x42475241 → argb.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x41424752 → rgba.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x52474241 → abgr.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x58524742 → bgr0.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x42475258 → 0rgb.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x58424752 → rgb0.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x52474258 → 0bgr.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30335241 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30334241 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30335258 → x2rgb10le.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30334258 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x36314752 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x56555941 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x56555958 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30303859 → gray.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x3231564e → nv12.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x3132564e → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x32595559 → yuyv422.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x59565955 → uyvy422.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x32315659 → yuv420p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30323449 → yuv420p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x50313134 → yuv411p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x48323234 → yuv422p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x56323234 → yuv440p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x50343434 → yuv444p.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x33434d49 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30313050 → p010le.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x32313050 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x36313050 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30313259 → y210le.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x32313259 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x36313259 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x30313459 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x32313459 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x36313459 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x50424752 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Format 0x50524742 → unknown.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Created surface 0.
Apr 13, 2023 00:05:36.554 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] [FFMPEG] - Direct mapping possible.
Apr 13, 2023 00:05:36.555 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Apr 13, 2023 00:05:36.555 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode/JobRunner] Job running: EAE_ROOT=/tmp/pms-dbe5b710-928d-4a54-a71f-2c531d3932ef/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS=‘/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/e51a01b-4528-linux-x86_64/’ LIBVA_DRIVERS_PATH=/usr/lib/plexmediaserver/lib/dri X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxx4d33-a6b7-3eb82a9f6bd7 “/usr/lib/plexmediaserver/Plex Transcoder” -codec:0 hevc -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_device:0 vaapi -codec:1 truehd_eae -eae_prefix:1 l5pr5m4tm1cleumajmheoc9m_ -analyzeduration 20000000 -probesize 20000000 -i ‘/USB-Drive/Movies/WALL·E (2008) {imdb-tt0910970}/WALL·E (2008) {imdb-tt0910970} [Bluray-2160p][HDR10][TrueHD Atmos 7.1][x265]-Prof.mkv’ -filter_complex “[0:5]scale=3840:1600[0];[0:0][0]overlay[1];[1]scale=w=3840:h=1600:force_divisible_by=4[2];[2]format=p010,tonemap=mobius[3];[3]format=pix_fmts=nv12[4];[4]hwupload[5]” -map “[5]” -codec:0 h264_vaapi -b:0 45000k -maxrate:0 60000k -bufsize:0 120000k -r:0 23.809999999999999 -force_key_frames:0 “expr:gte(t,n_forced*1)” -filter_complex “[0:1] aresample=async=1:ochl=‘5.1’:rematrix_maxval=0.000000dB:osr=48000[6]” -map “[6]” -metadata:s:1 language=eng -codec:1 aac -b:1 774k -f dash -seg_duration 1 -dash_segment_type mp4 -init_seg_name ‘init-stream$RepresentationID$.m4s’ -media_seg_name ‘chunk-stream$RepresentationID$-$Number%05d$.m4s’ -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name “http://127.0.0.1:32400/video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/manifest?X-Plex-Http-Pipeline=infinite” -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -init_hw_device vaapi=vaapi:/dev/dri/renderD128 -filter_hw_device vaapi -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress
Apr 13, 2023 00:05:36.555 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode/JobRunner] In directory: “/tmp/Transcode/Sessions/plex-transcode-l5pr5m4tm1cleumajmheoc9m-d50e7b27-7661-4abc-a4df-1a8f177e7604”
Apr 13, 2023 00:05:36.555 [0x7f74d0109b38] DEBUG - [Req#112fc2/Transcode/JobRunner] Jobs: Starting child process with pid 465537
- These “Request/Completed” show data being , transcoded and stored in the output buffer (PGS subtitles are being burned into the video)
Apr 13, 2023 00:05:36.767 [0x7f74ceae8b38] DEBUG - Request: [127.0.0.1:39190 (Loopback)] PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=5&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (23 live) #112fd1 Signed-in Token (namast) (range: bytes=0-)
Apr 13, 2023 00:05:36.767 [0x7f74d3ff3b38] DEBUG - Completed: [127.0.0.1:39190] 200 PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=5&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (23 live) #112fd1 0ms 195 bytes (pipelined: 13) (range: bytes=0-)
Apr 13, 2023 00:05:36.767 [0x7f74cadf3b38] DEBUG - Request: [127.0.0.1:39190 (Loopback)] PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=6&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (23 live) #112fd2 Signed-in Token (namast) (range: bytes=0-)
Apr 13, 2023 00:05:36.767 [0x7f74d41f6b38] DEBUG - Completed: [127.0.0.1:39190] 200 PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=6&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=eng (23 live) #112fd2 0ms 195 bytes (pipelined: 14) (range: bytes=0-)
Apr 13, 2023 00:05:36.767 [0x7f74cdd1db38] DEBUG - Request: [127.0.0.1:39190 (Loopback)] PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=7&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=ara (23 live) #112fd3 Signed-in Token (namast) (range: bytes=0-)
Apr 13, 2023 00:05:36.767 [0x7f74d3ff3b38] DEBUG - Completed: [127.0.0.1:39190] 200 PUT /video/:/transcode/session/l5pr5m4tm1cleumajmheoc9m/d50e7b27-7661-4abc-a4df-1a8f177e7604/progress/streamDetail?index=7&id=0&codec=hdmv_pgs_subtitle&type=subtitle&language=ara (23 live) #112fd3 0ms 195 bytes (pipelined: 15) (range: bytes=0-)
At no point does the TV ‘GET’ the transcoded buffers for playback.
I see the same thing happening again for Plex/web
Q: What happens when you play something without subtitles in it?
