[SOLVED(ish)] How to remove an empty/incorrect Collection?
Hello, folks!
I’m finally starting to explore the Collections options in Plex. I really like this idea, but I’m finding the auto-creation of them to be all over the place. For example, I have a collection that was auto-generated called “Airplane.” But the poster art is for a 70’s B Movie called The Big Bus.
I don’t own a copy of the movie Airplane anywhere in my library, and even once I removed the films that were linked, this collection remains with zero items in my library.
So how do you remove a collection from Plex if there is nothing in it? I read elsewhere that it supposedly will just not exist if there is nothing in it. Sadly, that’s not what I’m experiencing right now.
Thanks in advance!
In Settings > Server > Library enable Allow Media Deletion.
Change to collections view
Delete the collections you don’t like/need
https://support.plex.tv/articles/201273953-collections/
Guys… I’m going to try the “delete” thing mentioned above by @tom80H, but this isn’t a media issue, it’s a tagging issue from what I understand. So, it would seem like this is more of a functionality problem. As an end user, I don’t want to allow my shared users to be able to delete media, I prefer to handle it server-side. Also, it leaves me to believe that I might be deleting media instead of just a collection tag. …if this is more than just a tag, as it suggests, then it’s definitely something that should be considered for improvement, in my opinion.
This is fixed in the latest version of Plex Web (version 3.47.1 - this is not yet bundled with the version of Plex Web installed with your server, you need to use https://app.plex.tv/desktop to use it):
  • Fixed collections not showing Delete action unless “Allow media deletion” is enabled
This is interesting. What is a “Fixed collection”?
The bug is fixed. Not the collections.
Oh, I see.
  • Fixed: Collections not showing Delete action unless “Allow media deletion” is enabled
@NewPlaza said:
Oh, I see.
Confirmed. I just checked and it seems this has been corrected. Thanks, everyone!
