[SOLVED] "No soup for you" even after reinstall
This costs me several hours of tirelessly removing/installing/log off/log on etc, but I found the solution.
“if Plex is installed on a remote Linux server, you need to set up a SSH tunnel by executing the following command on your local computer. Replace 12.34.56.78 with the IP address of the remote Ubuntu server.”
ssh 12.34.56.78 -L 8888:localhost:32400
Then you can access Plex web interface via the following URL.
http://localhost:8888/web
So make sure you connect from the server itself, either via Remote Desktop or via SSH tunnel.
thanks to Linuxbabe: https://www.linuxbabe.com/ubuntu/install-plex-media-server-ubuntu-18-04
