! SOLVED ! Not Authorized After Re-installing Official Docker Image Unraid
Server Version#:
Ok I accidentally borked my Unraid Server and needed to reinstall Plex. After installing I now get a not authorized screen when trying to connect to the server for the first time. I have completely reformatted all my drives to remove any pre existing install, but the end result is the same. I need help. I have been using the official Plex docker image, but have tried others trying to get a different result. All results are the same no matter what docker image I use. Any help is appreciated.
Server Logs:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
chown: missing operand after ‘plex:plex’
Try ‘chown --help’ for more information.
Creating pref shell
Attempting to obtain server token from claim token
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7137 0 7137 0 0 13192 0 --:–:-- --:–:-- --:–:-- 13192
Token obtained successfully
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
plex.tv Password:
plex.tv Password Repeated:
IP Address of PMS server: 127.0.0.1
Comparing entered passwords
Comparing entered passwords ok
Validating IP address
Getting PMS Server Identifier
Getting PMS Server Identifier ok
Getting User Token from plex.tv
Getting User Token from plex.tv ok
Getting PMS Claim Token
Getting PMS Claim Token ok
Claiming server
Fatal error happened
HTTP returned Status 401
Ran the claim script and I get a fatal error
Tried to go to 192.167.1.20:32400/clients and I get a 401 Unauthorized warning.
OK looks like the server is claiming but i cannot access it. I tried to run the claim script from my windows machine with my servers ip address and no go.
Ok I changed my network internal ip address back into a range that was considered a private class c address and it works now.
